Golden Tee/Silver Strike combo game not quite working
br549autosales
Donor 2012-2013
Foley, Alabama
I have a dual game that I am working on that boots up and goes through all the tests and passes all from what I can tell. When the game comes up it is just for the Silver Strike Bowling game and I can't change it over to Golden Tee with the button on the control panel. When I press the Golden Tee button to switch over to it, the sound goes off from the Silver Strike Bowling, but the bowling game stays on the display. The guy I got it from said that when you press the button to switch over to Golden Tee, that you could hear the Golden Tee game, but it did not show up on the monitor (bowling game stays on instead) I did notice that upon the boot up sequence that I only saw info on the bowling game that loaded. Could there be something not connected to get the video from the Golden Tee? Looks as if there are two hard drives in the game, the one mounted on the inside of the cabinet with the red PCB board, which I believe is for the Silver Strike, and the other one I believe is for the Golden Tee. I think it is supposed to be a Golden Tee Fore Complete version if that matters or not.
Any ideas?
Can someone post some picture or direct me to a diagram of how the video cable should be connected on this dual game? I can press the button on the control panel to switch over to Golden Tee and I can coin up and hear the Golden Tee game playing, but I am not getting any pictures. I will include a few more pictures of the inside of the cabinet. The computer video cable that is coming off of the side of the dual board is not connected to anything, so that could be the issue, just need to know where it plugs into(1st two pictures)
Picture 5 above shows a video card with nothing plugged into it and the cable in question is hanging right by it. I'd start there.
I bought my kit from EastCoastAmusements. www.eastcoastamusements.com
Click on the contact link and you can email or call them.
I would contact Dick Dolan with any questions on this switcher.
I had problems with a Neotek monitor with this switcher. I could see the Silver Strike Bowling (SSB) on high resolution, but when I switched to the Golden Tee, the screen would show garbage. This was due to the Golden Tee game sending standard resolution, and the monitor not switching from VGA to CGA. I could move a jumper on the monitor neck board, and see the Golden Tee, but then the SSB was messed up. I swapped monitors with a WG 9400 and it solved the problem.
I'm attaching the instructions for this kit. Hope this helps.
Clay
  • THE PERFECT SOLUTION instructions.pdf
  • DIGITAL MONITOR CONNECTION INSTRUCTIONS for.pdf
This particular machine actually has a Samsung LCD monitor in it so it could be a setting since it is not a CRT monitor in it, but the Silver Strike shows up fine. No garbage or scrambled screen when I switch over to Golden Tee, just a black screen. I will start with the connector on picture 5 and read the info on the dual board. Thanks for the input on this guys.
