Golden tee question
tevans333
Bloomfield, Michigan
I've searched and can't find a definitive answer, just lots of conflicting posts.
How does the security work on Golden Tee Fore? There's 3 pieces, PCB, chip, hard drive. Which parts can be swapped around?
When you do upgrades, you normally leave the PCB and swap the HD and security chip.
Now, some people have said that once and upgrade has been done ('m guessing using the CD-ROM disc?) that the PCB code is registered on the hard drive and that the hard drive can no longer be swapped and work with a different PCB, but I'm not sure that is the case...
