Golden tee live motherboard list
Dssrocks
ALberta
Hello all, I am looking for a list of compatible golden tee live motherboards.
I have confirmed the following are compatible so far.
D915GUX
DG31PR
DB65AL
IMBM-B75A-A20
It would be greatly appreciated if anyone could add to this list.
from game.bin
D915GUX
DG31PR
DB65AL
IMBM-B75A-A20
Straight from the game code
865 and pga mobos do not work .....they are there for legacy/conditional checks
also some of the graphics cards were for i.t. testing only and will probably work but may fail when updating game.
Also depends on what software revision you are running as new cards and mobos get added generally via software patch as needed.
http://amusement.itsgames.com/downloads/instructions/Video Card Compatibility.pdf
Take info from i.t. website with a grain of salt as they rarely update it.
Big Denny - I just purchased a 2019 Golden Tee HE. It has a DG41TY motherboard and 750 ti video card. I was told I needed an i3 motherboard to display the latest animations. Do you have a newer list and do you know if the Dell XE2 is confirmed working?
Thanks in advance for any help.
Not worth the money to do the animations your setup is fine. Only waggle on tee off and you have to sit there for it to happen which you never do as you tee off almost immediately. A Db75en or newer board with a core i3 processor and a 750ti will get you there. The above is just my opinion cause I was after the same thing and found it was dumb haha.
Gumby510 - Thanks for the advice. Much appreciated.
btw - I'm the person who bought your SSB X drive and chip. Installing it today. Thanks!
Golden Tee Live 2015 - MSI G41M-P33 (MS-7592 V7.1)
I have a Golden Tee Live 2015 running on a MSI G41M-P33 (MS-7592 V7.1)
attachment.php
-Mike
