Golden tee live 2016 video card help
IAMWEASEL
Donor 2013
Melbourne, Australia
@bigdenny @toplessz
I have a gtl16 with a asus430 video card outputting at 720p via hdmi cable.
I'm a fussy bastard though and sourced a Zotac gtx 750ti as specced by it for video cards so that I can get a full 1080 HD experience.
So I've done the swap over and all is fine until it reaches the last screen before game loads.
Comes up with a message saying
Xorg cannot initialize video card: unknown
Then goes into reboot and constantly arrives at the same location.
I've contacted it about this and they seem to think it's odd as the drivers should be there and that it should recognize the video card and so on.
My software version is 11.04.09 so everything on my end supposedly checks out OK.
During the boot up ( 1st time after removing the Asus430) it does have a line that reads somethin like video card changed checking, configuring.
But that's it..... No 1080 for me.
It also says during boot up Nvidia driver: nvidia -linux-x86-319.23-tar.gz
Lm sensor: w83627ehf.
No matter if I'm using the Asus 430 or the Zotac 750ti the same Lm sensor number appears. I even removed the video card and went direct from the onboard video and same message/end result.
I'm taking a wild guess and assuming that the necessary drivers for the Zotac 750 aren't there or hidden from sight somehow. I even went to the Zotac website to download the drivers to USB stick and tried to boot the game with the usb stick and still nothing.
Is there something I'm missing?
Is there a way to install the Zotac 750 drivers onto the system?
I tried going into a command line by pressing control all and capital T (apparently this is how to get a command linenfor Linux based stuff) but that doesn't work either.
Also, even if I upgrade to 2017 (which Im also hoping to do soon) the problem will most likely carry over.
Dammit all I want is to see it in 1080 HD. Lol.
Any help would be greatly appreciated. Thanks in advance for taking the time to read my post.
11.04.10 update I have works. Are you sure you have a compatible zotac 750ti with 2gb gddr5? If its not Part Number 288-1N346-130Z8, this is probably the issue. The game looks specifically for this string. Also the 1gb gddr5 1gb gddr3 and 2gb gddr3 they will fail with your error.
is 288-1N346-130Z8 on the circuit board below the heat sync or on the back? or a similar number? I can make a torrent of the gt16 update and torrent it you just get me your email if you want
Just saw your second pic so the card is good... some times I.T.s literature isn't quite accurate.
I actually have this same issue. I have the same card and I could not get it to work with my GT2016 either. Same message and keeps rebooting. Verified the car Model, just hadn't gotten a chance to post about it yet.
Would love to be able to do 1080p with this.
I just double checked, and I have 11.04.03. Is there any chance I could get a link to the torrent for the update?
Also, do you have the 2014 update as well? I have version 9.04.07 of that, but it look like I need 9.04.09 according to IT.
GT 2015 update??
I have a 2015 GT version 10.04.03 and need 10.04.06 for my Zotac 750ti to work. I get same error messages... Game runs fine with older GPU but looks terrible so I picked up the 750ti not realizing I am running the incorrect version it seems. Could somebody help me with this??? Is it just a matter of downloading/purchasing a software update??
Yes, if you have a 32gb or larger usb stick and can use bittorrent I can torrent you that image and software to burn the usb update drive. Pm me your email Monday and i'll see what I can do afer I'm off work at 3pm eastern time
GT 2015 update??
did you ever get that video card working on your GTlive 2015?
Help idea if that torrent still exists. Have a gt15 that I need to update for new video card
You cant install new drivers to run a newer video card not going to work, at least not with out being able to change the code in ITs software extra its just not going to happen. IT was the very best at protecting their games from fraud or piracy. I think the gt 640 you already have can run 1080p, on silverstrike and others you cannot even get 1080 because the game was never developed to run at it. The dip switch setting on the I/O board determine this just switch then to HDMI and see if it loads on 1080p. If its not capable like ssb it will still work but only run on what it can 720p it shows you the resolution your using on the first splash screen an IT game loads up on.
Hi. Ya the zotac gt640 should work, but after getting a new motherboard the card only outputs VGA . So I was going to try and switch it out for a different card.
Ohh i see i didnt realize that card didnt have hdmi out, if it has dvi you should just need a dvi to hdmi adapter and you will get 1080p but you wont get audio obviously you would have to use speakers on cabinet. Im not sure what year the cards started having hdmi. This might help…
It does have HDMI out, but when I changed out the motherboard, HDMI stopped working. Changed a bunch of settings in the bios ,but still no HDMI.
