Golden Tee Live 2008
RalphT3
Cahokia Heights, Illinois
I have a buddy that has a Golden Tee Live 2008(I believe) that has the dual monitors. The lower one is a Wells Gardner flat screen CRT that is working for the most part, the whiter the game image is, it clicks and the picture does a tear look in the screen. Would that be the HOT and flyback going out on it. The number that I found on the chassis(quick look in dark) is PD278200 and I can't seem to find anything on this monitor as WGs website sucks now. The top LCD displays fine.
Would anybody know the part numbers for these 2 items and where to get a diagram for this monitor?
You probably have a D9400 in there, or possibly a newer model. Try doing a factory reset in the menu first...
if you look closer you probably have a 2792 not the 2782 you mention. This could be a monitor issue or maybe a video card issue. Take a look at the video card inside the case and see if the caps are swollen. If its fine, then, it might be time to do a cap kit on the chassis.
