Golden Tee Fore! monitor resolution question w/pics
voltron88x
Herndon, Virginia
I have a Golden Tee 2003. The monitor chassis is WGM-2274. When set to Standard Res, monitor works fine. When set to Med. Res, the monitor looks garbled as below (not vert. hold issue). Now I believe this chassis isn't OEM to GT Fore (research seems to indicate it's from Big Buck Hunter?) so my question is whether this is the result of some adjustable setting on my setup, or the monitor can't display Med. Res....which I'm assuming looks better than Standard Res.
Any insight would be appreciated. Thanks!
-Keith
2774 = 27" K7400
The K7400 is a standard-resolution monitor only, and will not display med-res. If you run it that way for too long, you'll likely blow your HOT.
The 7400 will work just fine in that game. No sense spending big bucks trying to track down a U5000 chassis (dual-res and direct swap with that chassis - uses the same yoke) or complete med-res monitor for a marginal (if any) improvement in the picture....
Ah thanks...now I know it's behaving as it should.
So med. res is not that much an improvement then? That makes me feel better. Just don't have anything to compare to.
