the amplifier will require +12V. it's doubtful your power supply isn't outputting that voltage, you'll have to look and see if you have a wire break somewhere (with the game off). additionally you'll need to inspect the speaker(s) and their wiring. I don't remember if those are mono or stereo, but you can do an ohm test at the speaker's + and - tabs and see if it matches the rating on the speaker. (4 or 8 ohm) if the speaker is reading open between the + and - tabs then the speaker is bad.
some things to get you started.
