Golden Tee Fore Audio Issues...High pitch squealling
Kevin13
Missouri
The audio during game play works fine, however, I notice some hissing and squealing in-sync with harddrive operation such as screen change, etc. These sounds are more noticeable during the attract and replay screens when there isn't any music playing (attract mode sound is set for occasionally). I've checked the grounds and there doesn't appear to be a ground loop issue...unless I'm missing something. Any other suggestions on what to check out? Should I replace the power supply? Any info. is appreciated.
Probably normal feedback from the HD. Not much that you can do about it, they all do it.
You could try unplugging the power to the LED display on top of the machine. They seem to generate some feedback similar to what you are describing.
Mine does it, too. I have no LED display. I am considering a switch to a Compact Flash card and losing the hard drive.
