Golden Tee Fore 2005 - How to wire Bill Validator
RCSP
Elm Grove, Wisconsin
I picked up a Golden Tee 2005 and have it at a local hobby store. I bought a used MARS Bill Validator (Model AE 2431-D5). The bill validator came with no wiring harness. The Golden Tee has a 9 pin connector (3x3), but the MARS has a 30 pin connector (15x2).
I need to know which wires on the Golden Tee 9 pin connector go to which pins on the MARS validator. I was hoping maybe somebody had done this before, or could suggest a wiring harness.
The schematic for the MARS is here if anyone wants to take a look (could not attach file, too large)
http://www.meitechnical.com/documen...|1172063843-166|1172063843-167|1172063843-153
Then click on "AE2400 Installation Guide (Rev G9)"
Thanks!
This is the manual you need:
http://www.happcontrols.com/images/pdf/ae2400_2.pdf
You just need to make a 4-wire connector to plug onto those 30 pins. You can do it with a connector as small as 10 pins, as long as you put it on the right spot.
Connect two wires to the 120vac inside the cab (like what lights your marquee light) and connect them to pin 4 (neutral) and pin 20 (hot).
Then connect two wires to one of the coin switches, on the same lugs as the ground and COIN wire. Connect the ground wire to Pin 1 and the COIN wire to pin 16.
Set the dip switches on the side of the acceptor like this:
1 - ON
2 - ON
3 - OFF
4 - ON
5 - OFF
6 - ON (if you want to accept $5 bills)
7 - ON
8 - OFF
Then go into your game menu and set the pricing as you want...
