Golden Tee Fore 2005 Blue Screen Help
OU Flight
Spring, Texas
Just picked up a Golden Tee Fore 2005 and all I get when powered on is a blue screen. The 2 green LEDs on the main board both flash regularly, the red IDE light flashes about once every 10 - 15 seconds. I can hear the hard drive spinning and working some but not a lot. No game Sounds. Any sugestions on where to start on where the problem is? I checked the voltage at the boot ROM and get 5.10. I have tried to boot in normal and opperator mode with no change. The only other thing I see working is the LED banner above the marquee. It is displaying a message from the bar the game from. Does the banner get it's info from the hard drive?
Thanks for the help.
Ok, after reading another thread, I turned down the blue on the neck board (it was cranked all the way up). Now I have a somewhat pulsating white screen, and I notice when I hear the hard drive make noise the screen shrinks in the vertical direction by about 1/3 for just a second. Don't know if that means anything.
