jukebox10
Power applied Game appears to come up with message saying "detecting IDE Harddrive" counting up to 35 error message appears NO HARDDRIVE DETECTED code 2 will reset in 10 secs or press start. After 10 secs big red box saying NO SIGNAL then resets back to detecting IDE harddrive goes thru sequence again. Pressed start button on startup the big red box saying NO SIGNAL appears. This is a golden tee with the green board. I replaced the hard drive with a known good Harddrive, same messages. Check the power into the harddrive from the power supply. Red wire (+5vdc) the Yellow wire (+12vdc) I have reseated all the cables NO LUCK. Does anyone have any suggestions?? Thanks for helping
