I keep getting a Low Voltage message an occasionally the board just quits. If I move the power supply a little it re-boots. Is the power supply bad or is it just maybe a loose wire?
If your power supply has a +5 voltage adjustment knob, you can put a meter on it and turn it up a little until it gives the Voltage OK message. If it says Voltage High then you turned it up too high.
If you don't have an adjustment pot, then you need to replace the power supply...
