Golden Tee and Big Buck Hunter problems
AlucardXP
West Islip, New York
Ok so I have a stack of boards that need repairs. I have a BBH and 2 Golden Tee Completes that all do the same thing...All they do when powered on is keep resetting. The power LED (near the modem) just blinks. Anyone have this issue before and been able to fix it? My BBH board only had that 1 LED flashing and I was able to get the other status light to come on but thats as far as I got with it. The GTC boards both have the status lights on already. All of them are also green boards too.
For my big buck hunter resetting issue, I had to jack up the voltage so when testing at the board, it was near 5.1V. Also, had to power the hard drive directly off the power supply, not using the power port on the PCB.
Hmm, I havent tried to jack up the voltage yet. I have checked it to make sure it was at 5 volts. I have mine powered by either with no difference. My BBH board has to get powered through the power connectors since it doesnt have 5v, 12v, and ground on the jamma connector.
