Golden Tee '99 Power problem
Adamdiz
Corunna, Michigan
Now that I was able to get to the PCB (thanks again everyone) I need to figure out what the problem is with my game. Once in a while it works perfectly, but 90% of the time it wont turn on.
When I turn it on, the header sign and monitor turn on, but the pcb and coin lights do not.
Ive looked at all the connectors and they looks to be solid and good. Where should I start?
Gt 99
Use a volt meter and check for a 120 vac at the switching power supply, If you have it,then change out the switching power supply.
RJ
Looks my power supply is the problem. Im getting nothing on my multimeter, its dead. Where can i purchase a new one? The power supply honestly looks like one from a computer.
power supply
computer supply supply store, Comp Usa or Tiger Direct, FRY's. should run you around $30.00 -$40.00
Pull the model number off the supply, wattage and the dimensions and any other features like an on off button, Main AC passes threw the power supply on it's way to the monitors isolation transformer, etc. That pertains to your setup.
RJ
RJ
Thanks, purchased a new one on ebay today
