Golden Tee 2k5... 2011 Rav4... Will It Fit?
jalpert
Colorado
I'm looking at picking up a Golden Tee 2005. Anyone have any idea if it'll fit in my 2011 Rav4? I don't think the Rav's have been redesigned since 2006....
Is it a dedicated cab? If it is, I'm thinking its not gonna fit. Those are huge. You can unplug the harnesses and pull the whole control panel out, but I still think the cab might be too deep to lay on its back and clear the roof of your truck.
I can get some dimensions off mine if it'll help.
Just looking at the pic, I don't think so. You would have to lay it on its side, but even then it looks like it will be too wide. The side hinged door isn't going to help either.
I don't think it'll fit either. It's 72" tall so on it's back it's 72" long. If it was around the corner it would fit, but it's 90 minutes away.
Thanks for the input guys.
Now you are just looking at it all wrong. :)
Once you get there, you will figure out a solution so it is not a wasted trip.
The height isn't a problem if you can pull the passenger seat up. I have had an Asteroids in there, and it is the same height. I just think it will be too wide. That cab looks ridiculously deep.
I took the control panel off and slid it on its back into my wife's Chrysler Pacifica. The deepest part stuck out the back, but the door came down enough to hold it in. I don't know how a Rav4 compares to a Pacifica, but if they are close it should work.
