Golden Tee 2k stopped working
tinsley
Connecticut
My GT 2k was working fine 2 days ago. Having a cookout today and went to get everything fired up, and GT2k is a no go. When powered on no sounds are heard and no picture come on the screen. When powered off you can see the monitor loosing power. What should I look for to fix this machine?
gt
power supply,or ac going to power supply.
I went to look at one the other day with this issue, and found the JAMMA connector had popped loose...
modessitt: i tried reseating the jamma connector, same results. any other suggestions?
Check fuses and check power supply voltages. If the monitor is powering up, you need to figure out why the board isn't...
