Golden Tee 2K - I have vertical color stripes on screen
doggsq
Ohio
I have an issue where based on the shirt color of my golfer, I get vertical stripes (about an inch wide) on my screen matching the color of the golfers shirt. It basically goes colored stripe, normal game, colored stripe, normal game picture, etc... across the screen.
How can I get rid of these vertical stripes? Is it a wire or some kind of chip issue? Otherwise the game works perfect, even with the stripes the game is not effected except for the solid color stripes blocking some of the picture.
Maybe try running a system test and see if everything checks out ok or if any parts fail. This may give you an idea of where to begin. Someone on here may have a better idea of what is going on.
Probably a bad solder connection on either the GROMs or the surface mount chip that has a bajillion pins on it. These boards are easy to damage by flexing.
