Golden tee 2008 reboots when hitting the trackball
Tcolton
Missouri
Hello all,
I have a Golden Tee unplugged 2008/Silver Strike 2009 that while playing Golden Tee was rebooting when I would hit the trackball hard. I rewired a few bad splices on the button/trackball, and thought the problem was solved.... But rebooted in the middle of game while hitting a button and/or trackball (not hard) last night...
Any ideas? Power supply issue? Doesn't seem to happen when playing Silver Strike, then again I do not play it as much.
I do have the perfect solution as well. However I had to swap out my monitor and haven't run the Green and Blue ground through the JAMMA/Perfect Solution yet.... I manually swap the VGA in the coin door.
Thanks!
Todd
Is it in an area where static is an issue? I had a couple games in a bowling alley once that reset all the time when you touched them, we fixed it by putting a rubber mat in front of them! Craziness.
Interesting! Worth a try.
It's a concrete floor... Shouldn't be too much static electricity, but I'm sure the track ball creates some.
