Hi all, I have a Golden Tee 2007 Live that started having lines on the top of the image on the main CRT screen. Before I could get in there and change the vertical circuit caps the image went to a blur, way out of focus to the point you just see a blur of light colors changing. The model is a Kortek KT-2914DF. Please don't ask me to adjust the focus, we all know that will not fix it.
If I can fix it that would be great. If not has anyone converted one of these to a newer LCD monitor?
Thanks in advance for your help.
You might check the focus wire at the neck board is in tight.
I would lean more to flyback or cold solder joints on the fly the grounding pins
for Focus and screen pots. I dought its the tube..just my 2 cents..
I'm sure its time for a cap kit.if never replaced before.
replace the vertical ic and check R212 measure's correct may look overheated
and changed value and r206 is .47 .5 watt. and r207 is correct.
Even After caps and ic replaced still vertical issues,check the resistors.
I've replaced caps before and monitor dead or chirping and vertical ic
was shorted forcing the secondary voltages to go up and down.Unless you would
like to troubleshoot it after a cap kit,just add it to a repair.
Its on my parts list,along with a few other issues that fail on this model..
Its a good chassis to repair don't get me wrong.Tip don't factory reset untill
you have to it repaired first..it will alter the geometry and you will have to readjust it..
Good Luck!
