midcoastsurf
I have a GT 2005 that I have been working on for a while now. The monitor is a Pentranics 1132 "33" monitor. I tested the rgb drive transistors on the neckboard and the all test the same. I also tested continuity at the transistors and they tested good as well. There were some small sparks inside the tube by the neck board when I turned the machine off...after hooking it back up after the testing. Is the red gun stuck on? Here's a picture...there are also some lines that run horizontally across the screen.
