Golden tee 2005 monitor replacement
Duhaas
Wisconsin
Looking to replace monitor on my golden tee 2005. Been trying to understand if I can replace with an LCD. Sounds like if I get a converter it's possible?? Anyone have any good links to help ke understand a bit more. Was looking at aver key 300 gold.
Either standard-res or medium-res will work via dip switch. if you want to use an LCD, then you need a VGA converter...
Thanks, any thoughts on how the guy from that one thread was able to do LCD without converter? Also trying to figure out best way to remove old 25 in monitor
If you get a Golden Tee Live setup, then you won't need a converter because the setup is changed and it output VGA.
Someone here has a thread where they mention cutting the tops off of GT's and attaching LCD's. See if you can find him and ask him how he did it...
thanks for following up, any chance my golden tee 2002 can be upgraded to a live kit?
It can, but it's not easy. The Live system uses a completely different setup that the 2002-2005/Complete setup. Plus, it has you install and LCD screen up top...
