Golden Tee 2004 died
mrsodapop
Lawton, Michigan
I am checking this out for a friend, he has a GT 2004 that just stopped working. I went over to check it, and this is what I found: When powered up, there is no sounds, no displays on screen, no response from control panel buttons, and no response from test button. The monitor seems to be working good, I can turn up the brightness and get a light blue screen. Checked power supply voltages at the PCB, have a rock solid 5.1 vdc, I did try and turn it up to 5.4vdc, but no change. When powered on, it sounds like the hard drive is powering up, there are 4 red LEDs that stay on constantly, 1 greed LED that flashes(D5R?), and 1 "status 1" LED that stays on constantly. It is a green PCB if that helps.
Can anybody help?
Aaron
