Golden Tee 05 Help
waterloobearing
Iowa
Screen shows the following message
UNABLE TO OPEN BINARY BOOT FILE
BOOT FAILURE: PROGRAM LOAD FAILED
FATAL ERROR: Failed to load boot file, code 3
Board will reset in 10 seconds
Press start to reset
Any ideas on what the problem may be? I also attached a pic of the screen
Thanks for any help
over time the switching power supplies can drift with the voltages and need readjustment
i'd hook up a multimeter and see what the +5V is at and you might find its low
dont adjust it over 5.26 for very long or the chips can get damaged
