Golden Axe marquee measurements?
Ghostnuke
Lawrence, Kansas
Can anyone provide me with the measurements of an uncut Golden Axe marquee? I thought the one I have wasn't cut, but it turns out it was.
It'll probably be smaller than the marquee area in the cabinet I'll be putting it in, so I need to come up with some way to fix that as well. I was thinking maybe another sheet of thin plexi behind it, and then mask off the area around the marquee with some black poster board?
Since they were kits weren't they all cut to fit whatever cab they were installed in?
The ones that were cut, yeah. I'm looking for the dimensions of an uncut one. :) And then ultimately I'll need to actually find an uncut one...
i haven't ever seen an uncut one.
i have GA in a Bosconian which means the marquee is Pac-sized; i think it might be full-height but cut on the sides.
you could always get the repro from gameongrafix.com and have it made exactly to size. they no longer list their repro graphics but you can search for them by name and they'll still make 'em.
was this the Golden Axe that was at the show?
yeah, that was my Golden Axe at the show. i'm glad it seemed to get a bunch of play. next year if it still have it it'll probably be Altered Beast just to mix things up.
Ok, let's forget about uncut measurements and assume I'll just use the marquee I have. How would you guys handle using a marquee that is smaller than the marquee area of the cabinet?
I'm thinking I'll put a thin piece of clear plex behind it, and then black posterboard around the area not covered by the marquee.
I would say most of them are going too be sizes 22inch too 25inch
