Golden Axe: 10 Watt pot? Wat?
Jaak
Donor 2024-2025
West Kelowna, BC
So I'm working on wiring up the sound on my Golden Axe project cabinet and the install manual says to use a 100 ohm 10watt pot for volume control. That seems extreme. Those kind of pots are wire wound monsters. This has to be a mistake.
The Sega part number I'm looking at is 4750-0049. This can't be right, right?
The PCB itself has a volumne knob on it. You plug the Jamma in (assuming that is attached to a speaker) and raise the volume on the PCB.
