TrevEB
Ok, this question has sort of been asked before, but the resulting answer wasn't quite correct.
I have a horizontal mount Electrohome G07. with some burn.
I may be able to get a replacement tube that has the anode on the side, instead of on the top, hence it must be a vertical mount tube?
Anyhow, is this tube going to work in a horizontal arrangement?
I've read earlier that it makes no difference, that the tubes are the same, but this replacement tube is different.
