ecwestjr
Had a GO7 with vertical collapse. Found the voltage on pin 6 of IC501 to be at 3.1 volts. Should be 10 volts. Well long story short found X102 was causing the 12 volts to be 3.1 volts. removed and voltage came right up to 10 volts on pin 6 and have full defelection.
Have had a bunch of other things cause vertical collapse but never X102 in the color input section.
New one for me. Now to get a few other problems ironed out on this chassis,
