I am using a GO7 with a 60n1 board. It has the typical curl to the left side. The monitor has been capped, new flyback, B+ adjusted to 119.8vdc (as close as I could get it), degaused and a 22uf@25V cap used in the sync upgrade. Bob Roberts upgrade directions says to adjust to a center point and adjust the H hold to remove the curl. No matter what I do the curl in the picture is still there. I adjust the H freq to no avail, the curl will not go away. Any ideas from the GO7 pros out there.
