Txny Mxnrxe
A while back I picked up a Galaga with a GO7 that had a non working chassis. The first thing I did was install a cap kit. I then noticed that I needed to replace the small fuse and the flyback. I replaced the flyback today and for the first time I have gotten some life out of the monitor. When I flip the switch, the screen comes on after a few seconds but the whole screen is green with lines changing between vertical and v-shaped from top to bottom. I have tried two pcbs and the results are the same. The only time I got something different was when I flipped the edge connector on the board and I got a high pitched sound and a faint image of the starfield and ram ok but it was inverted and still under the lines. This is my first machine and I admit I may not have connected everything correctly but I am stumped. Any and all help would be greatly appreciated.
