mrsodapop
Hi all,
Got a GO7 with low B+ that I can't seem to find what's causing it. Chassis has a Bob Roberts Deluxe kit installed(caps,flyback,HOT, VR, Hoz. coil, and fuses). B+ voltage is +96vdc as tested at the white wire on resistor R902. Turning B+ adj. pot has no effect. Voltage at the other end of R902 is +157vdc. I than pulled one leg on all diodes in the 900's section, they checked OK. Replaced X901 and X902. Still have same problem. I also replaced R908, and check for proper resistors at R 303,302,317, and 314. I also swapped out R904(filter cap). Problem still remains unchanged!
Anyone have any ideas?????
Thanks for any help
Aaron
Thanks for any help
Aaron
