im trying to get a 19inch go7 going, not so good. it was dead as a door nail, no picture, no neck glow, no voltage to discharge after its turned off . i replaced the caps, flyback and HOT.
now i get a full image on the screen, but it looks like no sync. B+ is 120 v. i hooked up a TPG , and it does nothing. usually if its not hooked up quite right, or something is else is wrong, scrolling thru the test will still produce red, blue, green. mine is just a washed out kinda grey, never changes.
other than replacing parts, im not a monitor guy. unless i can get steered in the right direction, i'm going to have to have someone repair it, or get a replacement. its a ms pacman. i think the chassis isnt orig, there are splices in the video signal harness in the game. i had another ms pacman had a WG chassis. ps- the neck board was cracked in transit, i solder bridged over the cracks, test for continuity, and epoxied it for stability.
any ideas, or anybody have a replacement or want to look at it?
thanks
thanks
