GO7 Issue
hockeyman44
St. Louis, Missouri
I had a 19" G07 that was working beautifully. The flyback flamed out. Not wanting my Gorf to be down for long, I thought I would just slap in 1 of my 2 spare working chassis. Neither of them will bring it back to life. I am not getting any neck glow with the working chassis. Never heard of a tube going bad when a flyback flames out. My B+ is high on both chassis when hooked up to this tube. I know they are fine on other tubes. What do I need to do to check out the tube and attempt to get it back up?
Did you check the 120 at the power connector? It's possible that you blew the fuse for the monitor power at the bottom of the cab...
Sounds like your "working spare" has issues. If the B+ is way high, check R908, X901, X902.
edit: have you checked the B+ on the other tube since discovering this issue? Just because it was okay then doesn't mean a part couldn't have died when you powered up this time.
