JoeB1355
so I took a centipede to work that I fixed up. I capped the monitor befroe I took it let it run for half a day in the garage all was good or so I thought!
took it to work its ran for 5 days then the monitor die no pic...
so I put out the chasis F901 was blown HOT still tested ok and the flyback wasn't crack that I could see.
so I put a new fuse in 901 and powered it up -- a little clicking then massive smoke and now the flyback has a crack!
did I fry it with the new fuse -- obviously its toast now - but if don't wanna put in a new one and watch it smoke
F901 didn't blow -- maybe because I put a 2 A in there as I didn't have a 1.5
I ordered some new parts to try and fix this -- anything else I can check to make sure I don't fry the new flyback?
