Go7 help..
local413
Longmeadow, Massachusetts
I've tried to install a Go7 in my moon patrol, no luck.. The connector that signal from the pcb to the monitor is a single one.. Not a 2 part connection.. I had a wells in it, worked fine.. But sold it with another game.. Is there a way to modify a Williams game to except a go7 monitor connector? Hope someone understands my post.. Thanks
pete
Let's see that connector on your Moon Patrol. And a screenshot.
It "should" work as-is. The video connector pinouts are identical, IIRC.
Sounds like one monitor uses a 10 pin molex connector and the other is set up to use the 2 molex connectors 6 pin and 4 pin or what ever the pin count is. Sounds like the fact that his current wiring has a single connector and the monitor he wants to drop in may use the split connector set up is confusing him. At least that's what I get from the post.
The chassis he had in there was a G07-CFO with the six pin connector. It "should" just plug right into the six pin connector on the chassis, bypassing the three pin G/+VS/+HS connector altogether.
Peter, did you try adjusting it out? Did it just not sync up?
The chassis he had in there was a G07-CFO with the six pin connector. It "should" just plug right into the six pin connector on the chassis, bypassing the three pin G/-VS/-HS connector altogether.
fixed it for ya
1899m go it!
Yes, the moon patrol has a 10 pin connector.. The Go7 was not installed in the moon before, I wanted to put it in it after I sold the wells that was in it.. So, how do I get the 10 pin connector to work with the 6/3 (go7) connections? Thanks for all the help! Peale, I threw this out there to get a second opinion as I couldn't explain the issue to you in the right words..
Pete
He sent me a picture...and from his above description (wg monitor in there before) and the picture this Moon Patrol is outputting negative sync. I thought MP had postive sync, like the other Williams titles?
Pete
Just cut the connector, no biggie.
