out of a ms pacman. monitor was dead, in HV shutdown. after re-cap, has an image and B+ is rock steady at 120. the image is too narrow for the screen, and wont hold still vertically, cant adj out a roll. however, if i increase the brightness knob on the flyback, the raster image does fill out the screen. im using RGBgnd on pins one-4, and neg sync on pin 6. could i be wrong on that? the game uses the other 3 pin connector for sync, should i be using that with the TPG? i knd of remember using the 3 pin on the last GO7 i worked on, but its been a while.
if its not that, what should i be looking at.
thanks
thanks
