Glitch after installing Super Pacman High Score Save
daley
San Rafael, California
So, I ordered the HSS kit from Arcadeshop. I received it today and installed it. I then played a couple games to test everything out and make sure there were no issues. Everything seemed fine and the scores were being saved. However, at one point after losing on the seventh level when the high score table appeared it displayed the 'highest level' I had achieved as level 70.
Whats up with this? Is this a glitch in the HSS or is it something else?
Thanks for the tip. Went ahead and reset it. By going in to test mode and pressing super, p1 start and p2 start all at the same time.
However now I have a new problem and therefore have no clue if that fixed the previous glitch. The board is constantly resetting and when it doesn't reset it is going in to test mode more often then not, even though the switch is off. I tried toggling the switch a couple times. Looks like the switch has gone bad and is closing the circuit even when off. So, need to replace it.
Pull them all back out and make sure that no legs got folded under and that they are firmly seated into the sockets when you re-install them. Sorry for the confusion.
Awesome. Works perfect.
Pulled and reseated all three chips. None of the legs were bent, but it did something because no issues now.
Got to level 13 and no wierdness on the high score table. Only time will tell if the level reporting glitch is gone.
By the way, that little test run was the best I have done on the game so far :)
Thanks for the advice!!
