Glass Cleaning HELP!!
Pizzadude
Donor 2016
Nepean, On, Canada
I am fixing up a machine that seems to have some kind of film or stain on the inside of the glass. I have tried all I can think of to remove it.. I know for sure its not paint.. HOW can I get rid of this film... ( pix attached.. )
Here is what I have tried already and has not worked..
Razor blade..
Bleach..
Magic Eraser..
CLR
Glass Cleaner
LCD Screen cleaner
Far short of taking a hammer to it, I'm at a loss...
It's probably nicotine/ tar buildup from being in a smoking environment . I would stay away from a magic eraser as that is essentially sanding the glass. Try isopropyl alcohol a paper towel. Will take down elbow grease but just try it in a corner or non visible spot first to see how it goes
I will give that a whirl.. I don't have much to loose lol.. It may be more gratifying to take the hammer to it and buy a new glass though...
Razor blade..
Bleach..
Magic Eraser..
CLR
Glass Cleaner
LCD Screen cleaner
Lol, did you really use bleach on it?
And what loss? Try some zippo lighter fluid first.
or just measure the piece.. go to a shop and have them cut you a brand
new piece of plexi glass.
I think even lowes sells plexiglass.
I would rather have the glass thats there.. and yes I tried bleach lol.. hmm good idea, lighter fluid and set it on fire ?? :)
if a razor blade wont remove it , i think it's etched from some type of a cleaner used on it. you need to polish it with tin oxide and a wool pad ( on a drill or polisher) any granite / countertop supply will have this.
Denatured alcohol and (believe it or not) coffee filters. They seem to be a little bit more abrasive than paper towels, but not enough to damage the surface. You have to work quickly though...the alcohol evaporates almost as soon as you pour it.
