Giant Headache
Deadpool66
Minnesota
Uck I decided to dig into this new project. I open the back and the wiring is a mess splices everywhere 3 jamma harness's all spliced together in some form. I basically just want to tear all of the wiring out and start over because its the biggest goddamn hack-job I have seen. Dude who sold it told me he worked for an op as repair tech are you kidding me!
Inside there is a Sega naomi setup with royal rumble and a blitz 2000 boardset. Does anyone know if I need a special harness for blitz or can I just order a new jamma harness's and add a switcher. I'm torn on which board to use and would like to keep both in the cab but wire it so it can be taken apart easily.
Its just awful Ill post some pics soon.
Blitz is Jamma, but it has some aux harnesses due to being four player and using 49 way joysticks. It may also have a stereo option, and that will not be included in a Jamma harness either.
A standard Jamma harness will get you most of the way there, and Bob may carry the aux harnesses - I know he carries most of the common aux harnesses.
