Ghouls N Ghosts Not Coining Up in 2 player cab
ashburton
Florida
I have a Ghouls N Ghosts PCB in my New Astro City Candy Cab and everything works great except that the button wired to provide credits is not responding on the game. It works for other games including other CPS1 games such as SF2CE, however when in the test menu the credit button is showing as the service button when I press it. Any suggestions would be great as I am frustrated beyond belief.
Check that the ground for that switch goes to the other grounds on the harness, some cabs rely on the board to connect all the grounds together and some boards rely on the harness to do it. If the board is relying on the cab and the cab is relying on the board you end up with split grounds and some buttons that don't work. The problem is made worse if there is a homemade harness in between the two if all the ground wires are not populated.
