Ghosts n Goblins won't start
Shirtswimmer
Ohio
I just recently acquired a Ghosts N Goblins game because the owner claimed it didn't work. The screen looks great, and the music is great, but the game won't start. I checked the manual for it and put it into free play mode but that hasn't helped. What should I look for? I know very little about these machines so anything helps. Thanks!
If the Start Button works, and it's wired to the haraness correctly, then you have a PCB problem. And to fix a PCB problem you will need a logic probe and some know how or a Tech.
Does the machine say it's on Free Play? If it is make sure the player 1 or player 2 buttons are wired. If they are, check them with a meter. They should ohm to zero when pressed and held. Check that and let us know.
