Ghosts`n Goblins original Monitor
Darius
Krummnussbaum, Lower-Austria, Austria
Hi,
i have bought an old Ghosts`n Goblins Cabinet which World Series Baseball and a noname "vertical" Monitor inside !!...please can somebody add a few pics from inside his original GG and from the original Monitor ? I want to check and will seek an original.
Which Monitortype is originally inside a GG ?
Many Thanks in advance
I have a dedicated; the monitor is a "Digital Controls" branded monitor. Mine has a Hantrex Chassis. This is not mine, but similar:
I've seen several pics of DEDICATED GnG with the Hantarex.
But with a GnG kit, the odds are any common 19" monitor was used in any random conversion.
So, OP, is your cabinet a dedicated one?
i hope it is an original Cabinet....as said i have bought it as "an old GG Cabinet with World Series Baseball" and was a bit dissapointed as i got it because i hoped i could easily remove the World SEries CP-unit and PCB and could add the original PCB, Marquee, Bezel i have.
But my Cabinet seems to be factory converted to Cinematronic World Series...could this be happened ?
As you can see the metal CP looks like also factory built for World Series...no holes for GG Buttons and Joystick...
Somebody could have made the panel when it was converted.
I'd get some more pics up and maybe someone will be able to determine if it was originally GG.
I noticed that the lower marquee retainer bracket in yours has 3 evenly spaced(looks like it to me) screws and the pic VC posted has 4 evenly spaced. They could have used both for all I know and not sure why anyone would change that for a conversion but I'd see if there is evidence of another bracket being installed at one point(unused screw holes), I'd do the same with the control panel mounting screws.
Many Thanks...can you tell me which Hantarex Monitor ? I think a MTC 9000 ?
looks like MTC 900E
I have an id sticker on the upper right side that matches the monitor. Here's some pics
Some more nice dedicated pics in this old FS thread ->
2020-06-21-13-27-28-jpg.441364
Many Thanks for your replies. OK - Hantarex MTC 900E - this is a common Monitor here in Europe....wondering that this type is originally in an US Cabinet...never heard before on any other game in the US.
I have found an original PCB-Cage for GG months ago and it looks also different as on the picture above...were there different versions available ?
