getting close on the wgk7000, now for r101 question
Cartouche
Southington, Connecticut
I feel like i'm really getting close on fixing this monitor.
This resistor (r101) had a blackened pad, so I cleaned up and re-soldered - getting continuity now.
It's rated 6.8k ohms, 5%, 3watts. My DMM SLOWLY tops out at 6k ohms when measuring it. Is this too low? Or is it within acceptable limits? Just wondering if I should swing by the electronics shop while I'm out today.
Thanks,
Marc
itll probably be ok, you could pull one leg and recheck..
that one does tend to change value over time because it runs so damn hot..
if you can get one locally, they by all means replace it.... if not id just run it...
