priglmeier Well-known member Donor 2016 VAPS Joined Feb 26, 2008 Messages 1,696 Reaction score 25 Location richfield, Minnesota Jul 14, 2009 #1 How do you get a 48 in 1 PCB to save games again after it erases your scores?
Deadly New member VAPS Joined Feb 10, 2006 Messages 6,162 Reaction score 31 Location Gresham, Oregon Jul 14, 2009 #2 I would assume it's the same process as the 60-1 http://www.jammaboards.com/arcade_manuals/60-in-1_iCade_Classic_Arcade_Manual_Online.pdf Dipswitch 3 to enable or disable. Did yours remove the scores WITHOUT using the dip switch? Last edited: Jul 14, 2009
OP OP priglmeier Well-known member Donor 2016 VAPS Joined Feb 26, 2008 Messages 1,696 Reaction score 25 Location richfield, Minnesota Jul 14, 2009 #3 Deadly said: I would assume it's the same process as the 60-1 http://www.jammaboards.com/arcade_manuals/60-in-1_iCade_Classic_Arcade_Manual_Online.pdf Dipswitch 3 to enable or disable. Did yours remove the scores WITHOUT using the dip switch? Click to expand... YES. It removed the scores without using the dip switch and now I would like it to work again.
keithsarcade Well-known member VAPS Joined Nov 27, 2008 Messages 8,875 Reaction score 160 Location St Peters, Missouri Jul 14, 2009 #4 Go into the test menu. In the I/O test, make sure Dip Sw. 3 is working.
OP OP priglmeier Well-known member Donor 2016 VAPS Joined Feb 26, 2008 Messages 1,696 Reaction score 25 Location richfield, Minnesota Jul 14, 2009 #5 good DIP looked fine but was not quite clicked in anymore. It was really hard to se this in the cab. Moved it back and forth a couple of times and powered it on. ALL IS GOOD.
