elkor
I don't know if this is a commonly known fix but I thought I would put it up anyway.
If you own a Getaway HSII then the chances are better than average that you have a problem with the machine not releasing all the balls for multiball.
What usually happens is it will release the first ball but not the rest until it does a ball search after the first ball has drained.
The problem is the coil activated post that retains the balls.
This guy gets sloppy with time and when the balls are on the wire form they no longer register as the balls are out of alignment.
I have heard some punters just change the coil sleeve but this doesn't always fix the problem (didn't on my Getaway).
Anyway all you need is a flipper bush and three self tapper screws.
You need to modify the bush a little but it's quite easy to do.
The hard part is getting into here. What a pain in the arse!
