Getaway HSII assistance j206
Tron1969
America, Ohio
I am helping a friend get his HS2 up and running. Everything works except the three pop bumper switches and the two metal rail return switches. After looking in the manual they are all on j206 6 green wire with blue strip.
I found the connector on the cpu board plugged into j207 so I switched it to j206 and there was no change in symptoms, I assume that j207 and j206 are interchangeable since all the rest of the switches continued to work after the switch. This also tells me that there is not a fuse issue since the rest of the switches work correct?
Any Ideas as where to look next?
Thanks in advance.
Continuity of the green/blue wire from the farthest switch to the cpu ?
If no broken wire then pull the connector and with a wire a diode simulate a switch closure from ground to the green wire/blue stripe pin and see if they all work, if not you lost a switch IC.
