Generic cab sizes for Marquees and Bezels
PrairieDillo
Donor 2011, 2024
Well so I am ordering a bunch of glass for Dynamos MVS's etc that I have. I wanted to have a spread sheet of all of the sizes and think that there should be a resource to check if a marquee is going to be big enough for your quick conversion cabs.
Please add to this list in the format that I'm using and I may link to a spreadsheet once the list is big enough. Obviously I don't have everything so any help to document would be awesome.
Dynamo HS1/HS2
Marquee 23-3/4"W x 7-5/8"H
Bezel 23-3/4"W x 23-3/4"H
Dynamo HS5
Marquee 25-3/4"W x 7-3/4"H
Bezel 25-3/4"W x 25-3/4"H
3KOAM K3 "Z-back"
Marquee 25-1/2"W x 7/3/4"H
Bezel 25-1/2"W x 25-1/2"H
Capcom Big Blue
Marquee - 27"Wx15"H
Bezel - TBD
Midway Universal (MK/NBA Jam)
Marquee 25"W x 7-1/2"H
Bezel 25"W x 25"H
Angled Cab
Marquee 23-1/2"W x 6-5/8"H
Bezel 23-1/2"W x 23-1/2"H
MVS 25 v1 (big red machines)
Glass 23-3/4" x 22 Tinted 10%
The HS-1 bezel is actually 23 11/16" by 23 11/16". Not a huge difference but just thought I would point it out.
Wecome to the forums.
I measured a few bezels and will keep to my original measurement. Thanks but no. I don't think they would have used such an odd measurement.
I have 6 HS1/HS2 machines.
I only have one HS1, and measured mine about a dozen times but wasn't confident in the measurements so I googled around.
http://www.drzero.org/videogames/dynamo/Parts.pdf
Page 3, about the middle of the page, the HS-1 plexi is listed as 23 11/16" x 23 11/16". The bezel should be the same, no?
Very, very far from an expert but just wanted to show where I got my information from.
And thanks for welcoming me, I hope to learn a lot here. In the process of trying to fix up a HS1 cab with SFII in it. Learning as I go.
I just measured the gap on 3 different HS1/2 cabs and the cab gap width is 23 7/8" wide so a 23 3/4" wide glass fits perfectly. I also measured 3 different bezels so I'm not going to change my measurement. I'm sure that they report smaller just so that you never cut one too big. If you don't go above 23-3/4" wide you should be good.
