Ok, I'm gonna say I don't think you should be messing with CRT's and monitors in general if you don't understand the basics of how electronics work first. Which you've demonstrated multiple times in your threads and questions.
If you did want to go ahead with it though, then it really depends on how "drop-in" of a replacement you want.
@greedycrisp posted the spreadsheet of consumer TV's that have been measured but basically if you want to mate a CRT to a chassis with as little fuss as possible then you need a tube that has the same connector as the chassis' neck board, or connector if it doesn't use a neck board, and ideally the tube should have a yoke installed with compatible ohm/inductance readings. Finding a tube with a compatible yoke on them is difficult for some chassis, like the G07 where the vertical coil measures about 50ohms, but a tube with a compatible connector could still be used if you were to swap in a compatible yoke. Installing a yoke would require you to converge the monitor which isn't exactly an easy process.
