tb lilley
I've got two Super Missile Attack Boards - the type that you plug into a Missile Command PCB.
One of the boards is for sure a GCC board - it is clearly marked as such.
The other one is a bit different - no GCC markings on it anywhere. The non-GCC board seems to have had some sort of replacement chip fitted in the middle of the board. This replacement chip is 16-pin and sits on a daughterboard with various jumpers ... The chip on the GCC board is 20 pin ....
Anyone care to speculate what this board is? Could be that GCC changed something in the middle of the production run (but seems unlikley). Or could it be a bootleg of the GCC board (which is itself is a bootleg)?
Neither board works - but probably won't take much to get up & running. Pics attached.
First 2 pics are GCC board - component and solder side. Second 2 pics are the other board.
