copious Well-known member VAPS Joined Oct 16, 2006 Messages 2,224 Reaction score 94 Location Sparta, New Jersey May 19, 2011 #1 I got everything working on my Gauntlet2 PCB except the speech is choppy and barely ledgable. Is this the amp? Is there a way to test the amp switch channels? to determine the fault?
Vongoosewink Well-known member VAPS Joined Apr 7, 2011 Messages 2,337 Reaction score 60 Location Indiana May 19, 2011 #2 Does it quietly crackle and pop when the speech is supposed to happen? If so, I have been having the same problem, covered on this thread: http://forums.arcade-museum.com/showthread.php?t=180121 Lots of helpful suggestions so far, but no solution yet. But it might be useful to see what I tried.
OP OP copious Well-known member VAPS Joined Oct 16, 2006 Messages 2,224 Reaction score 94 Location Sparta, New Jersey May 19, 2011 #3 more like cuts in and out.
channelmanic Well-known member Donor 3 years: 2011-2013 VAPS Joined Apr 5, 2008 Messages 17,110 Reaction score 1,093 Location Texas May 20, 2011 #4 Use a scope and follow the outputs from the speech chip through the analog section until you find the culprit.
