Gauntlet monitor problem
Muerto
Invisible, smoke, Denmark
Finally, got some time to work on my Gauntlet, though...
As you can see, the picture is not centered! - and after using 5 min or so to trying
to get it centered i gave up *:( - what can be the problem?
The monitor i used for this is _NOT_ the same that was in the cab! (but can that make a difference?)
Since we don't know what monitor is in it, we can't tell you anything...
The 2 "dials" i used to stop the picture from rolling is the 2 circled.
the one to the right, i should bearly touch, before the image rolled down or up... - only when i got the image, it stopped rolling...
the dial to the left ajusted the image left/right, and this was not the sensitive..
Cap it first and always.
These monitors are a bitch to deal with. Start with a cap kit. The horizonal and vertical holds are sooooo sensitive on these monitors that a weak cap can be the difference. You will need to check the pots (controllers) as well. My last ordeal with a Hanni was a lot of little things that added up to sync issues. Good luck.
R
Some of these boards also had problems with the BIG power resistors (open). Can't hurt to check that too.....
